Функции
Dual-Boot Backup
1+1 Supervisor
Module Redundancy
1+1 Supervisor
Module Redundancy
N+M Power Supply Redundancy
1+1 Fan Redundancy
1+1 Fan Redundancy
RG-CS88-08
Supervisor module slots
Line card slot
Switch fabric module slot
9.6 Tbps
7200 Mpps
 Ingress
 Egress
35.6 kg (78.48 lbs)
 Supervisor module
 Service module
 Supervisor module:
CM88-CM: 8 GB
 Service module:
8 GB
 Supervisor module:
CM88-CM: DDR4 4 GB
 Service module:
DDR4 2 GB
 Supervisor module:
CM88-CM: DDR4 4GB
 Line Card:
32 MB
RG-CS88: < 176 W
 Supervisor module:
CM88-CM: < 50 W
 Service module:
CM88-48GT-H: < 75 W
CM88-48SFP-H: < 95 W
CM88-48XS-H: < 160 W
CM88-8CQ-H: < 130 W
 RG-PA600I-F: 600 W
power: 1,600 W
Right-to-rear airflow
 System power module
RG-CS88 Series
MPLS IPv6
MPLS 6VPE
IPv4/IPv6 IS-IS
Policy-based routing (PBR)
EVPN
IGMP snooping v1/v2/v3
MLD v1/v2 snooping
802.1p
CAR
VRRP for the super-VLAN
RG-CS88-08
CM88-CM
2.Power Modules and Fans
RG-PA600I-F
RG-PA1600I-F
M08-FAN
3.Line Cards
Commercial-grade line cards
CM88-48XS-H
CM88-8CQ-H
CM88-48GT-H
CM88-48SFP-H
How long is the warranty period of the RG-CS88-08 switch?
3 years
How many power supplies can the RG-CS88-08 switch be configured with?
A maximum of four power supplies can be configured.
66
I am using the RG-CS88-08 switch, and I need line cards that provide more 10GE ports. Which card is recommended?
The CM88-48XS-H with 48 10GE SFP+ ports is recommended.
68
加载失败
TOP
