20 x SFG (8 x 1G CWDM), 2 x 100G
RG-S7620-20SFX2CQ20 x SFX (8 x 10G CWDM), 2 x 100G
RG-S7610-10SFG2CQ10 x SFG (8 x 1G CWDM), 2 x 100G
RG-S7610-10SFX2CQ10 x SFX (8 x 10G CWDM), 2 x 100G
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
Fixed port |
10 x SFG 1000M hyper-converged ports 2 x 100G fixed ports (100G/40G, and 4 x 25G/4 x 10G) |
10 x SFX 10G hyper-converged ports 2 x 100G fixed ports (100G/40G, and 4 x 25G/4 x 10G) |
20 x SFG 1000M hyper-converged ports 2 x 100G fixed ports (100G/40G, and 4 x 25G/4 x 10G) |
20 x SFX 10G hyper-converged ports 2 x 100G fixed ports (100G/40G, and 4 x 25G/4 x 10G) |
Fan module slot |
4 x fan module slots (3+1 redundancy, at least three fan modules configured) |
3 x fan module slots (2+1 redundancy, at least two fan modules configured) |
Power module slot |
2 (1+1 redundancy) |
Fixed management port |
1 x console port, 1 x MGMT port, and 1 x USB 2.0 port |
Packet forwarding rate |
714 Mpps |
1786 Mpps |
833 Mpps |
2976 Mpps |
System switching capacity |
960 Gbps |
2.4 Tbps |
1.12 Tbps |
4 Tbps |
Number of MAC addresses |
128,000 |
128,000 |
128,000 |
128,000 |
96,000 |
96,000 |
96,000 |
96,000 |
350,000 (shared with IPv6 routing) |
4000 |
4,000 |
4,000 |
4,000 |
65,000 |
65,000 |
65,000 |
65,000 |
2,000 |
2,000 |
2,000 |
2,000 |
Ingress: 28,000 Egress: 4,000 |
Number of VSU members |
4 |
Expansion module type and slot |
M7600-2CQ (100G/40G, and 4 x 25G/4 x 10G) M7600-4GT4VS (optical port supporting 25G/10Gbase-R and 1000base-X) 1 x expansion module slot |
442 mm x 388 mm x 44 mm (17.40 in. x 15.28 in. x 1.73 in.), 1 RU |
442 mm x 388 mm x 88 mm (17.40 in. x 15.28 in. x 3.46 in.), 2 RU |
Weight (full configuration) |
10 kg (including four fan modules and two power modules) |
10.4 kg (excluding packaging, power modules, and expansion modules) |
CPU and Memory |
2.2 GHz quad-core processor |
Memory and storage |
SDRAM: DDR4 4 GB (compatibility with 8 GB) Flash memory: 16 GB BootROM: 16 MB |
Power and Consumption |
< 300 W |
< 300 W |
< 450 W |
< 450 W |
Maximum output power |
RG-PA550I II-F: 550 W |
Rated input voltage |
RG-PA550I II-F: AC input: 100 V AC to 240 V AC; 50/60 Hz HVDC input: 240 V DC |
RG-PA550I II-F: AC input: 90 V AC to 264 V AC; 47/63 Hz HVDC input: 192 V DC to 288 V DC |
> 200,000 hours |
Heat dissipation |
Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) |
Operating altitude |
0 m to 1,800 m (0 ft. to 5905.51 ft.) |
Operating noise |
< 50 dB (closed space)/78 dB (open space) |
Interface surge protection |
Communication port: 4 kV on the MGMT port |
Device Model |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
Ethernet switching |
Super-VLAN and private VLAN |
IP service |
Static ARP |
DHCP client |
DHCP relay |
DHCP server |
DHCP snooping |
GRE tunnel |
IP routing |
IPv4/IPv6 static routing |
OSPFv2 and OSPFv3 Graceful restart (GR) |
IPv4 IS-IS IPv6 IS-IS |
BGP4 and BGP4+ |
IPv4/IPv6 VRF |
IPv4/IPv6 PBR |
IGMPv1/v2/v3 |
IGMPv1/v2/v3 snooping |
IGMP fast leave |
PIM-SM |
PIM-DM |
PIM-SSM for IPv4 and IPv6 |
MLDv1 and MLDv2 |
MLD snooping |
PIM-SMv6 |
Multicast querier |
MPLS |
6PE/6VPE model interconnection with the IPv4/IPv6 MPLS backbone network |
MPLS MIB (RFC 1273, RFC 4265, and RFC 4382) (MPLS MIB, MPLS L3VPN STD MIB, MPLS LSR STD MIB, and MPLS VPN MIB) |
Expert-level ACLs (hardware ACLs based on the source and destination IP addresses and ports, and protocol type) |
IPv6 ACL |
ACL 80 |
Expert-level ACLs (hardware ACLs based on |
Port-based rate limiting |
Eight queues on each port |
Multiple AAA modes |
TACACS+ |
IEEE 802.1X authentication, MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication |
SSHv1 and SSHv2 |
Global IP-MAC binding |
Port security |
SAVI |
ARP spoofing prevention |
REUP |
IPv4 VRRP v2/v3 and IPv6 VRRP v3 |
BFD |
Hot swapping of power modules and fan modules |
Device Virtualization |
VSU |
NMS and Maintenance |
RSPAN and ERSPAN |
sFlow (network detection technology based on packet sampling, which is mainly used for traffic statistics and analysis in heavy-traffic scenarios) |
NTP and SNTP |
FTP and S TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) Various types of RMON groups, including event groups, alarm groups, history groups, and statistics groups, as well as private alarm extension groups |
NETCONF |
CWMP |
OpenFlow Special 1.0/1.3 Flow table analysis defined by all protocols Transmission of specified packets to the controller Configuring the controller's IP address and port Notifying port status changes to the controller |
VXLAN |
EVPN VXLAN tunnel establishment VLAN access to VXLAN IPv4 over IPv4 Distributed gateway IPv6 over IPv4 Using an SVI to connect to the VXLAN network Using a routed interface to connect to the VXLAN network Proxy ARP (replying with the actual MAC address)) ND proxy (replying with the actual MAC address) ND reply (replying with the actual MAC address) VXLAN EVPN VXLAN static route Anycast gateway VXLAN bridging mode VXLAN routing mode Proxy ARP (replying with the gateway MAC address) Configuring the UDP port number in VXLAN packets Static VXLAN tunnel creation |
Perform the following steps to configure an RG-S7600:
RG-S7610-10SFG2CQ |
CWDM switch, 1 RU, 10 x SFG 1000M interfaces, and 2 x 100G fixed uplink interfaces |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
CWDM switch, 2 RU, 20 x SFG 1000M interfaces, and 2 x 100G fixed uplink interfaces |
RG-S7620-20SFX2CQ |
RG-PA550I II-F |
550 W AC power module |
M7600-2CQ |
Expansion module, 2 x 100G optical interfaces |
M7600-4GT4VS |
Expansion module, 4 x electrical interfaces, and 4 x 1G/10G/25G optical interfaces |
