RG-MUX-8LC/LC Коммутаторы - 1
RG-MUX-8LC/LC Коммутаторы - 2
RG-MUX-8LC/LC Коммутаторы - 3
RG-MUX-8LC/LC Коммутаторы - 4
RG-MUX-8LC/LC Коммутаторы - 5
RG-MUX-8LC/LC Коммутаторы - 6
RG-MUX-8LC/LC Коммутаторы - 7
RG-MUX-8LC/LC Коммутаторы - 8
RG-MUX-8LC/LC Коммутаторы - 9
RG-MUX-8LC/LC Коммутаторы - 10
RG-MUX-8LC/LC All-Optical Modular 8-Port Transparent Distribution Device
  • CWDM technology with zero fiber splitting, providing exclusive indoor bandwidth of 10 Gbps/1 Gbps
Функции
RG-MUX-8LC/LC 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded.
The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
RG-MUX-8LC/LC
RG-MUX-8LC/LC
8-port transparent distribution device on the building side. A single port supports 1000M and 10G rates.
Center Wavelength
1271 nm to 1571 nm (CWDM)
Channel Spacing
20 nm
Channel Bandwidth
±6 nm
Insertion Loss
< 3.7 dB
Return Loss
> 45 dB
Polarization Dependent Loss
< 0.3 dB
Adjacent Channel Isolation
> 25 dB
Non-adjacent Channel Isolation
> 35 dB
Connector
LC/UPC
0°C to 55°C (32°F to 131°F) at the  altitude of 0 m to 1800 m (0 ft. to 5905.51 ft.)
5% RH to 95% RH
5% RH to 95% RH
Standards
GR-1221-Core and GR-1209-Core
Net Weight
< 0.25 kg (0.55 lbs)
RG-MUX-8LC/LC-H
RG-MUX-8LC/LC-H
8-port transparent distribution switch on the building side. A single port supports 1000M and 10G rates.
Center Wavelength
Channel Spacing
20 nm
Channel Bandwidth
±6 nm
Insertion Loss
< 2.6 dB
Return Loss
> 45 dB
< 0.3 dB
> 25 dB
> 35 dB
Connector
LC/UPC
–0°C to 55°C (32°F to 131°F, altitude: 0 ft. to 5905.51 ft.)
5% RH to 95% RH
5% RH to 95% RH
Standard
Net Weight
< 0.25 kg (0.551 lbs)
RG-MUX-EXT
RG-MUX-EXT
Expansion module of the transparent distribution device on the building side, which is also an optical splitter. It supports 2:N dual uplinks and is equipped with patch cables.
Wavelength Range
1271 nm to 1571 nm
Channel Spacing
20 nm
Channel Bandwidth
±6 nm
Insertion Loss
< 4.2 dB
Return Loss
> 45 dB
< 0.3 dB
Connector
LC/UPC
5% RH to 95% RH
5% RH to 95% RH
Standard
Net Weight
< 0.15 kg (0.33 lbs)
RG-MUX-BOX
RG-MUX-BOX
Chassis for transparent distribution device on the building side with six slots, which is fit for 8-port transparent distribution device or splitter.
5% RH to 95% RH
5% RH to 95% RH
Net Weight
0.9 kg (1.98 lbs)
