RG-SG7008L Коммутаторы - 1
RG-SG7008L Коммутаторы - 2
RG-SG7008L Коммутаторы - 3
RG-SG7008L Коммутаторы - 4
RG-SG7008L Коммутаторы - 5
RG-SG7008L Коммутаторы - 6
RG-SG7008L Коммутаторы - 7
RG-SG7008L Коммутаторы - 8
RG-SG7008L Коммутаторы - 9
Функции
View product
View size
RG-SG7008L
Management ports
Module slots
1 x hard disk slot
Multi-service card slots
M7008L-RCM (routing card)
Common interface card slots
Hard disk slot
6.4 Tbps/64 Tbps
2880 Mpps/12600 Mpps
Power Supply and Fan
RG-PA180I-F:
 Input: 90 V–290 V AC
RG-PA650I-P-F:
Power redundancy
Fixed fan modules
3 x built-in fan modules
5% RH to 95% RH
Product Feature
RG-SG7008L
Switching module
4000 IEEE 802.1Q VLANs
Link aggregation
Spanning tree protocols
IPv6 DHCP server
IPv6 DHCP snooping
IPv6 DHCP client
IPv6 DHCP relay
MLD Snooping and MLD
PIM for IPv6
MAC-based extended ACLs
Basic security features
BPDU Guard
Management features
WIS-based management
High reliability
Hot swapping of power modules
Routing module
IPv4 features
VRRP, FTP, and TFTP
ECMP and WCMP
DNS resolution and smart DNS
NTP server and NTP client
IPv6 features
VRRPv3, BFDv6, and 6VPE
SSL VPN
Egress features
Flow log and URL log
Security zone
URL filtering
Self-defined URL and URL logs
Attack prevention
ARP attack prevention
Secure address binding
Port scan attack prevention
ICMP flood attack prevention
Smurf attack prevention
Teardrop attack prevention
Application Identification
P2P applications
Streaming media software
Chat software
Game software
Content audit
Email content audit
IM audit
BBS forum content audit
Search engine audit
EMB module
Device status query
Network configuration
Zero- configuration features
Syslog, Telnet, and SNMP
Diagnosis tools
Operations on devices
Quick configuration
Quick configuration
Operation log
Device upgrade
Device upgrade
Administrator account
Data backup and recovery
M7008L-RCM
Quad-core processor
BOOTROM
Flash Memory
4GB
4GB
External Port
Button
1 x FUNC button
Hot Swapping
EMC Standard
GB/T 9254.1
Safety Standard
GB 4943.1
0.30 kg (0.66 lbs)
M7000L-6XS
Port Type
Optical Module
SFP+ port
LED
RDY, Link/ACT LED
EMC Standard
GB/T 9254.1
Hot Swapping
0.30 kg (0.66 lbs)
M7000-HDD-1T
Hard Drive Type
Hard Disk Drive (HDD)
Capacity
1 TB
LED
DISK status LED
Hot Swapping
Not Supported
EMC Standard
GB/T 9254.1
Safety Standard
GB 4943.1
0.30 kg (0.66 lbs)
M7000L-8GT
Port
Transmission Medium
LED
Hot Swapping
EMC Standard
GB/T 9254.1
Safety Standard
GB 4943.1
0.20 kg (0.44 lbs)
M7000L-8GT-HP
Port
 Note
Transmission Medium
LED
Hot Swapping
EMC Standard
GB/T 9254.1
Safety Standard
GB 4943.1
0.25 kg (0.55 lbs)
M7000L-8SFP
Port
Optical Module
LED
Hot Swapping
EMC Standard
GB/T 9254.1
Safety Standard
GB 4943.1
0.25 kg (0.55 lbs)
RG-PA180I-F
Rated Voltage Range
Maximum Voltage Range
Maximum Output Power
180 W
HVDC Parameters
0.45 kg (0.99 lbs)
Power Cord
10 A
RG-PA650I-P-F
Rated Voltage Range
HVDC Parameters
0.85 kg (1.87 lbs)
Power Cord
10 A
RG-SG7008L
Multi-service Cards
M7008L-RCM
M7000L-6XS
Interface Cards
M7000L-8GT
M7000L-8GT-HP
M7000L-8SFP
Power Modules
RG-PA180I-F
RG-PA650I-P-F
