RG-SF2920-16GT2MG2XS-P Коммутаторы - 1
RG-SF2920-16GT2MG2XS-P Коммутаторы - 2
RG-SF2920-16GT2MG2XS-P Коммутаторы - 3
RG-SF2920-16GT2MG2XS-P Коммутаторы - 4
RG-SF2920-16GT2MG2XS-P Коммутаторы - 5
RG-SF2920-16GT2MG2XS-P Коммутаторы - 6
  • Various port combinations, surge protection greater than 8 kV, 16 x 10/100/1000BASE-T ports, ports 3 to 8 PoE/PoE+ supported, 2 x 1G/2.5G/5GBASE-T ports, ports 1 to 2 PoE/PoE+ supported, and 2 x 1GE/10GE SFP+ ports for uplink
Функции
This switch provides 16 x 10/100/1000BASE-T ports, ports 3 to 8 PoE/PoE+ supported, 2 x 1G/2.5G/5GBASE-T ports, ports 1 to 2 PoE/PoE+ supported, 2 x 1GE/10GE SFP+ uplink ports, rich interfaces, supporting full service expansion.
8 x 10/100/1000BASE-T ports
1 x 1GE/2.5GE SFP port
2 x 1G/2.5GBASE-T ports
2 x 1GE SFP ports
2 x 1GE SFP ports
System switching capacity *2
1 MB
256 MB
512 MB DDR3
1.5 MB
56.5 Mpps
76 Gbps
256 MB
512 MB DDR3
1.5 MB
1.18 kg (2.6 lbs)
1.43 kg (3.15 lbs)
1.74 kg (3.84 lbs)
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
2.81 kg (6.19 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
Fixed power supply: 70 W
Fixed power supply: 150 W
The maximum power is 45 W
8.5 W
10 W (without PoE load)
55 W (full PoE load)
16.5 W (without PoE load)
141.5 W (full PoE load)
25 W (without PoE load)
150 W (full PoE load)
RG-SF2920 Series
Air discharge: 15 kV
Contact discharge: 8 kV
RG-SF2920 Series
RG-SF2920U
RG-SF2920
SPAN, RSPAN and ERSPAN
CWDM
XG-SFP-LR(A1-4)-H
XG-SFP-LR(A1-8)-H
GE-SFP-LR(A1-4)-H
GE-SFP-LR(A1-8)-H
