RG-S2910-48GT4XS-E, 48-Port Gigabit L2+ Managed Switch with SFP+
Full gigabit access to LANs in large enterprise parks, gigabit access to commercial systems
Функции
Diverse ports
Secure and Reliable Hardware
and Software
Strict component selection
3-month reliability testing
Accurate traffic statistics
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
24 x 10/100/1000 BASE-T ports
48 10/100/1000 BASE-T ports
Fans modules
Fixed fans
Fixed fans
128Gbps
176Gbps
96Mpps
132Mpps
RAM
512MB
16K
In: 1,500
Out: 500
Lightning
Protection on
Power Port
Common Mode
6KV/Differential
Mode 6KV
Lightening
Protection on
Communication
Port
Common Mode 6KV
440 × 260 × 43.6
440 × 260 × 43.6
≤3.5kg
≤4kg
AC input: 100V to 240V AC
HVDC input: 192V to 290V DC
90V to 264V AC
90V to 264V AC
Input current
0.5A to 0.1A
0.8A to 0.5A
24W
50W
MTBF (hours)
0°C to 50°C
-40°C to 70°C
10% to 90%RH
5% to 95%RH
IEC 60950-1, EN 60950-1
Emission
Standards
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
4K 802.1q VLANs
MAC-based VLAN
Protocol-based VLAN
IP subnet-based VLAN
Guest VLAN
N:1 VLAN switching
1:1 VLAN switching
Standard/Extended/Expert ACL
Extended MAC ACL
ACL logging
ACL counter
ACL remark
Global ACL
ACL redirect
Time-based ACL
Router ACL
VLAN ACL
Port-Based ACL
Dynamic QoS
Over devices mirroring
VLAN-based mirroring
VLAN-filtering mirroring
AP-port mirroring, RSPAN
ERSPAN
Spanning Tree
Protocols
IPv6 DHCP snooping
IPv6 DHCP client
IPv6 DHCP relay
DHCP Snooping Option 82
Layer 2 protocols
128
OpenFlow 1.0 & 1.3
VSU (Virtual
Switch Unit)
IPv4/ IPv6 static route
IPv6
Basic protocols
VSU features
Management features
CLI (Telnet / Console)
SSH
NTP/SNTP, FTP, TFTP
HTTP or HTTPS
Hot Patch
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
RG-S2910C-24GT2XS-HP-E
RG-S2910C-48GT2XS-HP-E
Optional Accessories
M2910-01XS
M2910-02XS
RG-M5000E-DC500P
