4 x GE electrical ports, 1 x 2.5GE optical port, 1 x DC power connector, PoE/PoE+
RG-PF2920-DPBOX-P1 x GE electrical port, 1 x GE optical port, 1 x DC power connector, PoE/PoE+
Model (PoE) |
RG-PF2920U-4GT1MS-P |
RG-PF2920-DPBOX-P |
Fixed ports |
4 x 10M/100M/1000M auto-negotiation electrical ports 1 x 1000M/2.5G SFP port |
1 x 10M/100M/1000M auto-negotiation electrical port 1 x GE SFP port |
Switching capacity |
13 Gbps |
N/A |
Packet forwarding rate |
9.7 Mpps |
N/A |
SFP port |
2500Base-X and 1000Base-X supported |
Power supply |
Powered by a hybrid cable from the PoF switch Maximum voltage range: 42 V DC to 57 V DC Rated voltage range: 44 V DC to 56 V DC Rated current: 1.3 A |
Powered by a hybrid cable from the PoF switch Rated voltage: 44 V DC to 57 V DC Rated current: 0.75 A |
Leakage current to ground |
≤ 3.5 mA |
N/A |
EEE |
Supported |
Not supported |
Ethernet electrical ports 1–4 support PoE. Max. overall PoE output power: 60 W The maximum number of PoE devices supported by the switch is determined by the PoE output power of the switch and the actual power of the PoE devices. |
1 x downlink POE/POE+ port |
Overall power consumption |
Without PoE load: ≤ 15 W With PoE full load: ≤ 75 W |
Without PoE load: ≤ 3 W Overall power (PoE+) ≤ 33 W |
Installed in a rack or unconfined space: 0ºC to 45ºC (32ºF to 113ºF) at a height below 1,800 m (1.12 miles) above the sea level Installed on a workbench or in an ELV box: 0ºC to 40ºC (32ºF to 104ºF) at a height below 1,800 m (1.12 miles) above the sea level Note: At a height ranging from 1800 m (1.12 miles) to 5000 m (3.11 miles) above the sea level, the maximum operating temperature decreases by 1°C (1.8°F) for every increase in altitude of 220 m (721.78 ft.). |
10% to 90% RH |
10% to 90% RH |
5% to 90% RH |
5% to 95% RH |
Fan |
Intelligent temperature control |
The temperature alarm and overheat protection functions are supported. |
Not supported |
Electromagnetic compatibility (EMC) |
GB/T9254.1 |
GB/T9254.1 |
Safety standard |
GB 4943.1 |
GB 4943.1 |
Dimension (W x D x H) |
200 mm x 170 mm x 55 mm (7.87 in. x 6.69 in. x 2.17 in.) |
120 mm x 25 mm x 40 mm (4.72 in. x 0.98 in. x 1.57 in.) |
1.5 kg (3.30 lbs, including the package) |
0.2 kg (0.44 lbs, including the package) |
Model (PoE) |
RG-PF2920-DPBOX-P |
802.1Q VLAN |
4K IEEE 802.1Q VLANs Port-based VLAN |
Not supported |
DHCP |
DHCP client |
Not supported |
Filtering of invalid MAC addresses Broadcast storm suppression Password protection CPP Port protection |
Not supported |
EEE |
APD port sleeping |
Not supported |
Management |
CLI-based configuration and management not required, visualized Web management IoT MQTT Syslog/Debug and SNTP |
Not supported |
The 4-port PoE/PoE+ switch provides 1 x uplink GE optical port and 4 x downlink 10M/100M/1000M auto-negotiation electrical ports, and is connected to the hybrid cable (1 x GE/2.5GE SFP port and a round DC plug). The switch supports PoE/POE+ power supply of 4 x 15 W (or 2 x 30 W). A fanless design is adopted, and an optical link fault LED is provided. |
RG-PF2920-DPBOX-P |
The single-port media converter is connected to a hybrid cable in the uplink direction (GE SFP port + circular DC socket) and provides a PoE/PoE+ port in the downlink direction. |
