RG-DEMUX/MUX Series 48-Port Combiner/Transparent Distribution Device
  • The 48-port combiner and transparent distribution device provide 48 ports for device access at full load. They use six WDM fibers for transmission, which effectively reduces trunk optical fibers required in buildings.
  • All-optical deployment makes upgrade easy. One-time deployment of combiner and transparent distribution device may free you from upgrade worries for ten years.
  • Cooperation with the INC controller to achieve easy and efficient O&M management
Функции
RG-DEMUX/MUX Combiner/Transparent Distribution Device
The Simplified Optical Ethernet solution adopts the Ethernet architecture. The transparent distribution device implements transparent transmission from the core network to access network. The network architecture transformation from three tiers to two tiers together with the colored optical Ethernet technology makes distribution nodes passive completely.
The all-optical network involves only passive devices, making distribution nodes passive completely and freeing you from troubles of the ELV rooms
Active devices are replaced by new passive devices. Only optical fibers, combiners, and transparent distribution devices are required between the core side and access side. ELV rooms and power supplies are not required, which effectively reduces line deployment, lowers the device failure rate, and exempts ELV rooms from management and O&M.
The unique colored optical technology implements zero optical splitting and exclusive 1G/10G bandwidth to the room
The combiner and transparent distribution device utilize the unique colored optical technology to implement transparent transmission from the core network to the access network and provide 1:1 exclusive 1G/10G bandwidth to the room. They meet the access requirements of high-bandwidth devices as well as network requirements of terminals.
All-optical deployment, ease of upgrade, flexible expansion of all-optical network
When the bandwidth is upgraded from 10 Gbps to 25 Gbps, the trunk cabling area does not need to be changed. Switches of different rates, combiners, and transparent distribution devices can be replaced or added based on service requirements. The devices are plug and play and supports fast onboarding and expansion.
Cooperation with INC Controller to Achieve Easy and Efficient O&M Management
You can check the link health status, networking alarms and fault sources by INC which dramatically improves the troubleshooting efficiency.
Switches can be flexibly replaced based on service requirements with no need for reconfiguration. Service ports support mixed insertion, facilitating automatic O&M.
RG-DEMUX-24LC/LC
RG-DEMUX(C)-24LC/LC
RG-DEMUX-48LC/LC
RG-MUX-24LC/LC
RG-MUX(C)-24LC/LC
RG-MUX-48LC/LC
Name
48-port demultiplexer
3 groups
3 groups
6 groups
3 groups
3 groups
3 groups
Installation location
Core side
Core side
Core side
Building side
Building side
Building side
24
24
24
24
Dimension (W × D × H)
216.4 mm * 207 mm *33 mm
297.6 mm * 438.5 mm * 40.2 mm
216.4 mm * 207 mm * 33 mm
210.2 mm * 440 mm * 39.8 mm
RG-DEMUX-48LC/LC
48-port demultiplexer, with 6 demultiplexing ports (number of trunk fiber-optic cables can be connected)
Center wavelength
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
Channel bandwidth
± 6.5 nm
Insertion loss
 4 dB (demultiplxer and transparent multiplexer)
Return loss
>45 dB
Polarization dependent loss
< 0.3 dB
Adjacent channel isolation
>25 dB
>35 dB
Connector
LC/UPC
-40°C to 85 °C
10% to 90% RH
5% to 90% RH
Standards
GR-1221-Core and GR-1209-Core
3.49 kg (net weight)
RG-MUX-48LC/LC
48-port transparent multiplexer, with 6 demultiplexing ports (number of trunk fiber-optic cables can be connected)
Center wavelength
Channel spacing
20 nm
Channel bandwidth
±6.5 nm
Insertion loss
Return loss
> 45 dB
< 0.3 dB
>25 dB
>35 dB
Connector
LC/UPC
-40°C to 85 °C
10% to 90% RH
5% to 90% RH
Standards
3.01 kg (net weight)
加载失败
TOP
